USACI Competing Questions
KenC210
All the way forward would be acceptable. If you had a 90degree angle seat back and the whole seat slid forward maxed out then you would still be stock class. As long as the seat stays in and your enclosure doesn't stick out horribly. Keep in mind, all amps and stuff have to be in "stock" locations.. So I don't think you can put them anywhere except behind the seat. If it was me I'd just do a super stock build and take the back seat out, much easier to work with. Below the window line and behind the b pillar
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Stock Locations for the amps? My truck has a factory truck has the upgrade sound and the factory amp is under the passenger seat. So the amps and things would have to be located there? Since it does have the factory amp and was planning on keeping the factory radio i would need a processor. But if i have to have everything behind the rear seat then you are right everything would be extremely difficult to stay in a stock class.
  • Who's Online   1 Member, 0 Anonymous, 1621 Guests (See full list)
