4 channel
Desousa93
i wanna buy one 4 channel amp to run my front stage.. was looking at the 125.4 because it has so many crossover options..
i wanna run 4 kicker tweeters (already have them from an old setup.) 4ohm active on sundown amp. but if i wire the channel 1/2 to an 8ohm load on each side it would be 120/2= 60 watts so 30 watts each tweet.
then i for midrange was thinking the Crescendo PWX 6.5 or maybe neopro 6.5 (not a VS thread please dont lock)at 125 watts on channel 3/4..
would this work? id love for somebody from sundown to chime in
:domodance: :domodance::morepower1:New Build in the Making :morepower1: :domodance: :domodance:
1999 Infiniti I30 Limited
if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
quote name="ToNasty" post="2708528" timestamp="1391807918"]
You can just run active if the amp is capable. Run the tweets off ch 1-2 and the mids off 3-4
Itd be okay to do 8ohm load on channel 1/2 and 4ohm on 3/4?
They are. But I have 4 tweeters. And an email from kickr said if I put over 38 watts rms itll overdrive the tweeter.. so if I wired it to 8 ohm each side itd be 125/2 =62.5/2= 31.25 watts each tweeter
Lol yeah. Says it might handle 50 watts only if the signal is clean
  • Who's Online   0 Members, 0 Anonymous, 586 Guests (See full list)
