Desousa93 Posted February 10, 2014 Report Posted February 10, 2014 I dont know if I wanna go 12 ported at 33hz or 15 sealed.. I have room but idk what would sound better. I want loud but sound good too New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
MACnonsence6 Posted February 10, 2014 Report Posted February 10, 2014 i would recomend you do more reading and less posting @ 33hz best reading fq there is sealed box is easyer to build and generally have flatter fq responce across the band vs ported " not to say a ported cant do the same but generally require large boxes to do so." look into the differences between sealed and ported as well as the specs of a would be driver then decide I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
Desousa93 Posted February 10, 2014 Author Report Posted February 10, 2014 Well its either a xcon 12 ported or 15 xcon sealed off 1500 watts. New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
MACnonsence6 Posted February 10, 2014 Report Posted February 10, 2014 ok so look into the specs of each. get a speaker modeling program like bassbox 6 pro. use the specs and see what works best. people on this site will not spoon feed you as i have already learned unless u have a real issue no ones just gonna hand you information. being there the same series they should have the same motor so bl is consistant between the 2 choices. a 15 on the same power will be lower in ported v ported or sealed v sealed. if there both built to spec. again read before posting I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
john253a Posted February 10, 2014 Report Posted February 10, 2014 If you ask me What are your building skills like? What do you mainly lission to? How much net do you have?
Desousa93 Posted February 12, 2014 Author Report Posted February 12, 2014 If you ask me What are your building skills like? What do you mainly lission to? How much net do you have? 1 im decent with wood working, fiberglass ima beginner but can get it for free so its a thought 2 i listen to alot of rap and hip hop from eminem to waka flocka gucci mane.. and the occasional dubstep 3 i have 4.47 cuft internally with a double baffle. no port just a box.. i have a shitty 10" powerbass in a seald box and i like the sound. so i was thinking a 12 ported would be nice but a 15 sealed would probably kill the lows? New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Azagtoth502 Posted February 12, 2014 Report Posted February 12, 2014 Go ported. pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
john253a Posted February 13, 2014 Report Posted February 13, 2014 You nilly have enough for a ported 15
zayres29 Posted February 13, 2014 Report Posted February 13, 2014 seems to be a lot of these threads lately Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
