Soundqubed HDS200 12" Sub box Opinions on design asap!
Mikey Bates
Dimensions have to work with for a daily box to build are
29 wide
16 deep
and 18 high
93 civic hatch.
sub up port up
sub will be getting about 400rms out of 600
on torres i made this and want to know if it seems ok
34.58hz
1.73 net
24 wide
16 deep
14 high
sub up port up
1.75" wide port 14.5" tall
range it gives me is 21-28 port area and i have it at 25.38
port is 28 long.
Opinions
here the specs... Im guessing the valome is the recomended ? im not to sure.. this is all they give
Piston Diameter 254.0 mm Mounting Depth 6.5" Circle Cutout 11.1875" Outer Diameter 12 7/8 with gasket f(s) 39.03 Hz Q(ms) 5.367 Q(es) 0.587 Q(ts) 0.529 V(as) 29.700 liters
(1.409 cubic feet)
The box specs are the same as for there other series just finished building a box for 2 hds200 12 they reccomended the same that you see on there chart
http://www.soundqubed.com/Box-Sizes-and-Tuning-_ep_68.html
Well since im a new guy i have no idea how to read that chart.. but i want a ported box tuned at about 36hz (somewhat low) and my max dimensions are
Width:33inch
Height: 13-15
Depth: I'd like a max of 16inch (to have space in the trunk)
  • Who's Online   2 Members, 0 Anonymous, 2077 Guests (See full list)
