Sealing a wall off testing. Before and after. Any one?
Kyblack76
like i said, not the best pics or job, but it works!!!
Started the trim panels, you can also see the spanding foam filling the gaps , behind it, there´s gorilla tape, just like i did on the explorer
Done!!
P.s: the little box inside the port was something we tried for even more lows, actually worked nice :)
fuck..
looks better than my garbage
numbers, with power on this?
EDIT- was this where you only metered AFTER the seal?
Damn, id love to see before exactly, and after exactly
4 loudforce 700 watts subs 15" , sound nice for what they are, 2 loudforce 3000.1s wired at 1 ohm a piece, dc power 180A alt, D3100 on front and 3 nsb 110ft on the back, 4 runs of welding 0 cable.
Both of the cars i mentioned were tested before/after, i didn´t clamp before/after on this box i posted, only on the termlab, gained 2.1 dbs at peak frequency, gained more than 4 dbs from 31 to about 36 hz, so definitely louder on the lows!!
Once again, every application is different, maybe you won´t see such a big gain because your gaps were smaller, but it should definitely give you a nice increase
