Love the build and a awd frs would be sick, I'm not one for tuners 90% of the time cause everyone I see is running the hella flush and stretched tire and massive camber look. But I'm loved this car for sure has mods but all tasteful and not flashy or ricey. Btw love the powder coat on the rims
my tires are somewhat stretched, only cause i am using factory toyo tires on a 8.75 wide wheel, but deffinatly wouldnt go anymore than that, very little stretch anyways being its a 225/45 tire, and what sucks about the tc is the rear upper control arms are NOT adjustable, so naturally when the vehicle is lowered the rear cambers out, im at a -1.8 and -1.7, i got lucky, others see numbers as high as -3 with just springs... so a small amount of camber in the rear... they make aftermarket RUCAs for the vehicle now, but no reputable company has them yet, plus it isnt quite enough camber to throw my alignment totally off, and cause a dramatic un even wear on the tire, if i were to drop on coils i would consider it however.
Fuck the awd. They need to make it a factory boosted car
this, both would be king though lol, 4cyl 2.5l turbo would be perfect... they have a couple kits for them now for around 5k but the stock block cant handle more than like 15psi, people usually see about 290-310whp on a good tune, and about 400hp with a fully built engine @ about 25, but thats good money right there... and not as reliable of course
i have the money to boost, but IMO i'd rather have a car boosted from the factory than aftermarket anyday, reasons such as reliable and warranty reasons and such
mmm that sub! :wackit3:
yup, a lot bigger than i thought when i first got it lol
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
battery came in the other day, threw it in last night real quick.
ordered some wire, i swapped polarity locations, 12v lead had slack on it, and the ground i moved easily since it was just a 10mm nut right on the chassis about 6" from the battery
rigged it up for now to work, got more wire coming in to complete my big three, get a real ground on my battery and shorten up from batt to my fuse and what not, so not the prettiest now but it works lol
35D6B9BC-BDF6-4873-A484-D60A3763E88B_zps
FC1779E4-56C7-464E-BC98-6D84391A0DE6_zps
35A41FD8-D6E4-401C-B4F7-AA2A12AF4C13_zps
Team Sundown Audio
Thanks guys, hopin to get the box started next weekend, I'd like to this weekend but I'm heading to buffalo, ny for the NCAA tournament
Team Sundown Audio
Nice battery bro . So i have a question for you. Did you have to cut anything for the stock positive cable for it fit on the other side ,or did it have enough slack to to just bolt on to the battery? I know the negative is fairly simple to replace being just a bolt.
2010 Pathfinder
Sundown Audio - SAZ 4500- Zv.3 15"x 2 w/ Nightshade coils
Sundown Audio - SAX 100.4d- Focal Utopias 165w2 (fronts), rockford t1652 (rears)
DC Power Engineering - 270XP
Knukonceptz and Rockford 1/0 wire through out
XS Power D3100s x2 and a "god ol" Optima Yellow Top up front
theres a pair of zipties that i cut that run the power wire along side other wiring, i just cut them and it moved over easily
im waiting to get some 1/0 cause i have to extend my alt positive wire, and going to do a couple grounds in the engine bay
Team Sundown Audio
Cool nice to know. Thanks
2010 Pathfinder
Got some nice new 1/0 for my new engine bay wire runs, made a couple grounds and a new alternator run... i also just ordered 25ft of 3/4" techflex to clean up the wiring in the engine bay.. it is currently wire loomed but i really like the techflex look on wiring in the engine bay so that should be here tomorrow/wednesday.
E2DF28E1-12CE-4848-8BC4-732C1855451B_zps
Also, after i put my exhaust on i realized how weak the factory exhaust hangers were. exhaust would shake on startup and rattle if i hit a bump...so i ordered up some torque solution exhaust hangers(5) and got those installed really quick this weekend, made a huge difference... can barely make the exhaust move or shake by hand now, so it no longer hits the bottom of the car anymore
440969E1-4881-4CCC-B204-ACB70A81F7B6_zps
Team Sundown Audio
  • Who's Online   1 Member, 0 Anonymous, 1049 Guests (See full list)
