Miguels Posted February 14, 2014 Report Posted February 14, 2014 what if you do the D3100 in the front and a good cap in the rear.. just do 1 extra run of wire so you can transfer more power from the D3100 to the rear my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Desousa93 Posted February 14, 2014 Author Report Posted February 14, 2014 what if you do the D3100 in the front and a good cap in the rear.. just do 1 extra run of wire so you can transfer more power from the D3100 to the rear only cap i would even consider would be the ones @snowryder talks about... i cant find hte link but its on this forum http://www.ebay.com/itm/1500-Farad-KIT-Ultracapacitor-Engine-Start-Booster-Battery-Eliminator-Car-Audio-/301059034609?pt=US_Motherboard_CPU_Combos&hash=item4618844df1 New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Desousa93 Posted February 14, 2014 Author Report Posted February 14, 2014 Would I really need a second run of wire I plan on using 3/0 (000) welding cable New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
jmanjr82 Posted February 15, 2014 Report Posted February 15, 2014 I would lean towards doing 2 runs of OFC 1/0 over the welding cable. I agree with the big battery upfront as well. I would run the 3100 under the hood the biggest alt I could get on the car and the 2 runs of OFC to the rear along with big 3 in OFC.
Miguels Posted February 15, 2014 Report Posted February 15, 2014 the thing is since you have no battery in the rear 1 run wont be enough. if you get a rear battery then you are sucking up most of the juice from it with a 2 feet long wire so 1 run would be sufficient then my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Desousa93 Posted February 15, 2014 Author Report Posted February 15, 2014 So 2 runs of wire from batteery. Can i run that to a distro block or like a bus bar?? And I wanna do toolmaker dual inputs for the crescendo? Os it worth it? New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Desousa93 Posted February 15, 2014 Author Report Posted February 15, 2014 And maybe if dimensions can fit ill put a small battery in the back im not sure tho. And would it be better to do a ground block? New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Desousa93 Posted February 16, 2014 Author Report Posted February 16, 2014 Bump New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Desousa93 Posted February 20, 2014 Author Report Posted February 20, 2014 Bump New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
