Brandon Mendoza Posted February 13, 2014 Report Share Posted February 13, 2014 What do you guys normally use when doing this? I know it needs something to keep vibration down right? Link to comment Share on other sites More sharing options...
ROLEXrifleman Posted February 13, 2014 Report Share Posted February 13, 2014 Normally we use screws. and make sure they are down tight. Otherwise, its a moving vehicle hitting bumps. your always gonna have vibrations. Rolex you sicken me. Just let me finish my pie ~ Juice Link to comment Share on other sites More sharing options...
DubNDodge Posted February 13, 2014 Report Share Posted February 13, 2014 stick your forehead on the box. if you don't like the vibration you get when your system is going, then niether will your amp. These rubber corks are good for mounting amps. doesn't eliminate vibration completely. so a solid box is key here. http://www.widgetco.com/rubber '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult. Link to comment Share on other sites More sharing options...
Brandon Mendoza Posted February 13, 2014 Author Report Share Posted February 13, 2014 Maybe I miss worded it lol I know you need screws I'm asking to help with any possible vibration what can I use? I've seen like rubber pieces or something or I see that guy posted about rubber corks? Stuff like that. Link to comment Share on other sites More sharing options...
Brandon Mendoza Posted February 13, 2014 Author Report Share Posted February 13, 2014 Anything I can buy at like a Home Depot or something? I don't really wanna order anything I don't have to. Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted February 13, 2014 Report Share Posted February 13, 2014 I wouldn't mount to the box at all. I think what you are looking for are grommets. But they really won't do a thing. It will probably be better to have your amp as tight on the box as possible if you are going to do it that way Link to comment Share on other sites More sharing options...
DubNDodge Posted February 13, 2014 Report Share Posted February 13, 2014 There is no magical product that amplifier companies sell that eliminates box vibration. you either: 1. Build a SOLID box, with bracing maybe even some fiberglass. 2. Find some way to dampen the vibration when mounting the amps. (The link I provided. Like I said there is no "amplifier mounting rubber pieces". Be creative) 3. Don't give a fuck about mounting the amp to the box screw it down, call it a day. and hope to god you don't vibrate components of the amplifier off the board. 4. Make an amp rack not attached to the box. make sure it doesn't move around in the trunk. (assuming it is a trunk car) '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult. Link to comment Share on other sites More sharing options...
DubNDodge Posted February 13, 2014 Report Share Posted February 13, 2014 I wouldn't mount to the box at all. I think what you are looking for are grommets. But they really won't do a thing. It will probably be better to have your amp as tight on the box as possible if you are going to do it that way yes because having your amp mounted tight up against a vibrating board is the best option out there. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult. Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted February 13, 2014 Report Share Posted February 13, 2014 I wouldn't mount to the box at all. I think what you are looking for are grommets. But they really won't do a thing. It will probably be better to have your amp as tight on the box as possible if you are going to do it that way yes because having your amp mounted tight up against a vibrating board is the best option out there. I figured it might slow down the vibrations going to tha amp. Throw some some grommets in between the amp and the box and I'm pretty sure it would rattle more. But if you read the very first sentence I typed then you know what I would do. Link to comment Share on other sites More sharing options...
Brandon Mendoza Posted February 13, 2014 Author Report Share Posted February 13, 2014 As of right now I have a separate board I have my amp mounted to but It just doesn't look as clean and it takes up more space and moves around some so I thought maybe just mounting stuff directly to the box would work out better. I obviously knew vibration or w.e you call it or consider it would be an issue and that's why I asked what people who have mounted amps to boxes have used to help. I get that I can't fully eliminate it but I know you can take precautions to help with it. I'll just try to find something else to mount it to other then the box. It's in an expedition so maybe I'll just Meade it and mount them under the seat or on the seat or something. Link to comment Share on other sites More sharing options...
