Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
Hey man I read through the t line topic and wanted to build one instead of a ported box. Could you sketch me a design? I listen to slowed rap, bass mekanic, decaf..
Max dims in 98 dodge ram ext cab rear seat removed
50w 21d 40t. There is a little more room in height.
I have two sundown E12 on order! their dual 4 ohm
I was going to run one ohm final load
My amp is a rockford T500-1bdcp 800w@1 ohm
Sub specs:
Fs 35.8hz
Qes0.56
Qms6.79
Qts0.52
Le1.85mH
Vas47.6L
BL15.4NA
Cms0.13MM/N
Mms 156.6 grams
Sens n/a 1w/1m
Xmax 12mm one way
Rms 400w
Displacement .12ft cubed
Please help with some sketch or advice I think this t line would be better and easier to build than a sixth order someone else had suggested to me.
Thanks a lot,
James
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
2 Sundown E12 Ported 4cubes 35hz
Rockford P400-4
2 Infinity reference 3way 6x9
2 Polk DB 5 1/4
2x layer dynamat all doors
wanting to get a SA-8 V2 and wanna show people up and prove a 8 can be as loud as anything you throw at it and i know a T-line will doo
problem
dont know now to ago about making one let alone calculating how to make one
i need help!!!
2007 JEEP COMPASSDC LEVEL 4 18"AUDIOQUE AQ 2000.1ELEMENTAL DESIGN NINE.4
:bow28:
Sub specs:
Fs 35.8hz
Qes0.56
Qms6.79
Qts0.52
Le1.85mH
Vas47.6L
BL15.4NA
Cms0.13MM/N
Mms 156.6 grams
Sens n/a 1w/1m
Xmax 12mm one way
Rms 400w
Thanks a lot,
James
Do you want it to be as big as your dimensions? whats more important to you the height or the width?
you want the subs up or forward?
I am new to this but I think I have a ok grasp.
I need the practice on Sketch up.
As big as my dims u could take the height of it up to 50" lets see something man! Sub up port driver side or sub up port up
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
Rockford P400-4
2 Polk DB 5 1/4
GREAT STUFF GUYS IN SIMPLIFYING HOW TO MAKE A T-LINE.....ONE QUESTION I HAVE AND CONFUSE IS THAT I CANT FIGURE OUT THE WIDTH OF THE PORT HOW WIDE SINCE YOU GUYS STRESS A GOOD POINT IN HAVING A CONSTANT PORT..ALSO HOW BIG CAN I MAKE A BANGING T-LINE FOR A 2001 CHEVY ASTRO I AM OPEN FOR SAMPLES N DRAWINGS , I APPRECIATE THE HELP..THX
THESE ARE MY SPECS.......
1 - 12" ALPHASONIK MAYHEM PSW912..
FS - 35HZ
SD - 10.5
QTS - 0.374
QMS - 1.485
PORT LENGHT - 8.071
PORT AREA 78.53
http://alphasonik.com/index.php/en/support/ts-parameters.html
FS - 35HZ
SD - 10.5
QTS - 0.374
QMS - 1.485
PORT LENGHT - 8.071
PORT AREA 78.53
http://alphasonik.co...parameters.html
lol draw it up yourself or pay someone to do it. This stuff isn't that hard when you learn it, but it takes more than 5 minutes to do.
More box builds
I'm with captain stupid.
also please remove the capslock key from your keyboard
Hammerdown... 1%
Right around 36hz
50" X 27.25" X 17.5"
E12 Cutout:
Outside Diameter: 12 1/4"
Depth : 6 1/2"
Cut-Out: 11 3/16"
Will take 2 4'X8' sheets of wood:
y is there a section of the tunnel not calculated? when u see the line drawn down the middle. and how do you calculate what that should be for your application?
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
  • Who's Online   0 Members, 0 Anonymous, 1663 Guests (See full list)
