One Subwoofer Not Responding to Lows.
Exscathe
It does sound right to me also. You just may have a wire not snug or out of place. Dmm is a 2 sec check. So just make sure. If that's not it post pics and vid when you can
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
You need to upload to like photobucket then copy IMG code then paste
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Because most forums aren't image hosting sites. However they do allow embedding of images hosted on other sites ;)
I said I wired it to four ohms, and yes it does equal four ohms because I wired it in series and 1 x 4 = 4. I know that my subwoofers are ACTUALLY 0.7 ohms, so I actually get 2.8 ohms. Also I wired it to "4 ohms" because I don't have my H.O. Alternator yet so wiring to "4 ohms" is just fine since I don't have the electrical for 1 ohm load right now, also my amp os 0.5 ohms stable on strong electrical. Also if I have two Dual 1 ohm subs and I wired them in parallel I would be getting 0.25 ohms, not 1 ohm. To get one ohm I would wire in series parallel. I know what I am doing, I didn't need you to tell me how to wire my subs.
I suggest you use a volt meter and check the subs.... I know you know what your doing and all, but maybe a coil is blow.
Ok ^^ box, wires to subs next
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 842 Guests (See full list)
