sbg Posted February 17, 2014 Report Share Posted February 17, 2014 It does sound right to me also. You just may have a wire not snug or out of place. Dmm is a 2 sec check. So just make sure. If that's not it post pics and vid when you can 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
Exscathe Posted February 17, 2014 Author Report Share Posted February 17, 2014 Why can't I just copy paste image, da duq lol! Link to comment Share on other sites More sharing options...
sbg Posted February 17, 2014 Report Share Posted February 17, 2014 You need to upload to like photobucket then copy IMG code then paste 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
SnowDrifter Posted February 17, 2014 Report Share Posted February 17, 2014 Because most forums aren't image hosting sites. However they do allow embedding of images hosted on other sites ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Guest Posted February 17, 2014 Report Share Posted February 17, 2014 i use imgur http://imgur.com/ i make an album usually. upload from "computer". i cant visualize anything from reading text. Link to comment Share on other sites More sharing options...
poorfish88 Posted February 17, 2014 Report Share Posted February 17, 2014 I said I wired it to four ohms, and yes it does equal four ohms because I wired it in series and 1 x 4 = 4. I know that my subwoofers are ACTUALLY 0.7 ohms, so I actually get 2.8 ohms. Also I wired it to "4 ohms" because I don't have my H.O. Alternator yet so wiring to "4 ohms" is just fine since I don't have the electrical for 1 ohm load right now, also my amp os 0.5 ohms stable on strong electrical. Also if I have two Dual 1 ohm subs and I wired them in parallel I would be getting 0.25 ohms, not 1 ohm. To get one ohm I would wire in series parallel. I know what I am doing, I didn't need you to tell me how to wire my subs. I suggest you use a volt meter and check the subs.... I know you know what your doing and all, but maybe a coil is blow. Link to comment Share on other sites More sharing options...
Exscathe Posted February 17, 2014 Author Report Share Posted February 17, 2014 Well that one is a test. Link to comment Share on other sites More sharing options...
sbg Posted February 17, 2014 Report Share Posted February 17, 2014 Ok ^^ box, wires to subs next 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
Exscathe Posted February 17, 2014 Author Report Share Posted February 17, 2014 Some Woofer Porn. Link to comment Share on other sites More sharing options...
Guest Posted February 17, 2014 Report Share Posted February 17, 2014 nothing looks wrong so far Link to comment Share on other sites More sharing options...
