Kicker, Ascendant Audio Build Log Completed Pics!
port is on the smaller side, but I think it will work out okay. I've seen a decent amount of people have success with smaller ports. I guess we'll see, if there is any problems, its rebuild time :)
It looks fine thats just what people always say
TDH FTW !!!
Today, I started the trim panel. I have a plan of what I want it to look like in the end, hopefully I can obtain the results that I am looking for.
First I cut the wood (two main top and bottom pieces), then I cut out a bunch of curved braces, that way I could get a nice curve to the trim panel, after that I taped off the car in preparation of fiberglass.
Posted Image
Posted Image
Posted Image
Posted Image
I applied fleece, and then added resin, then a bunch of layers of fiberglass mat for some strength.
Posted Image
Posted Image
Posted Image
Posted Image
Nobody makes me bleed my own blood, NOBODY!!!
It didn't hit me until after I finished fiberblassing, that I probably could have cut some sort of tube (pvc, or sonotube) to get the same curve. Oh well, I am learning as I go along!
Here I added some fiberglass body filler to the ends where there is a weird curve to my car.
Posted Image
Posted Image
After everything was all set, I started a little bit of sanding.
Posted Image
Posted Image
Okay sorry for the delay in pics, I was out of town for a little, finally got to some more work.
After sanding down the fiberglass a little, I started to add some body filler. Sanding + more body filler = Lots of labor.
Posted Image
I then cut out the whole in which the ZX2500 will sit behind. I also got to work on some led's. Orange is one of my favorite colors, so that is what I chose.
Posted Image
Posted Image
Posted Image
Posted Image
Lookin good bro.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
Alright here we go. I decided that I want to make an insert to give it some contrast, and some curves. The actual panel will be in black while the insert and box will be the same color as the interior of my car. Here I cut out the insert to my desired shape.
Posted Image
Posted Image
Then I wrapped 5 layers of tape around the insert to account for the thickness of the material that I will use to wrap everything. After that I built up the sides, sanded, and got it rather smooth. It doesn't have to be absolutely perfect because it will be wrapped.
Posted Image
Posted Image
Posted Image
