cattskinner Posted February 21, 2014 Report Posted February 21, 2014 Greeting, I am a new member who's recently discovered Sundown Audio. I just bought a used Sundown 8" an eBay. The seller didn't have the original box, so I am a bit unsure just which model I have. Moreover, I plan to use it in a Tapped Horn build. TH's are tricky things, and if you don't have pretty exact spec's they can be a disaster. I'm getting set up to measure TS spec's on my own (can't find anyone around here that does that, so I might as well ... I love DIY), but in the meantime I want to narrow down my design simulations a bit with the manufacturer's spec's. This is a STRONG motor for its SD! So it's pretty finicky with what design it will work for (just judging by experimenting with the spec's of an SA-8v.2) ... designs for other 8's were all over the graph. I think I have either the v1.5 r the V1.75, judging by the basket (4-spoke/8-leg), and the DC resistance as measured by a cheapo tester bounces between 2.3 and 2.4 per voicecoil. Can anyone identify it, and WHAT ARE THE TS PARAMETERS? Thanks ahead, and glad to be joining you folks.
Azagtoth502 Posted February 21, 2014 Report Posted February 21, 2014 Post a few pictures. pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
Kyblack76 Posted February 21, 2014 Report Posted February 21, 2014 You could try the SUNDOWN section? That's where I'd go. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
