Yeah I have a hx2 power12 that cleansierra designed a box for. roughly 2.2 net tuned to 33-34 hz.
Haven't built it yet but i'm really hoping I can soon.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I'm sure you could at least sell them and find 2 more to buy.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
So, here is what I came up with:
Double baffled with center port. Tune is around 33 Hz, net airspace is right at 5 cubes(just a hair under if you want to add a little bracing). Port area is 58", which should be enough for those subs and the Xmax being what they were. Those are all of the important parts I can think of at this time. Here are the dimensions of what I came up with. All of the inner dimensions are 14.5" in height for ease of cutting and measuring.
Bottom and top
37X23"
Sides
14.5X21.5"
Front baffle
14.5X16.5"
Inner baffle
14.5X15"
Back
14.5X37"
Port extensions
18.25X14.5" with a 45 degree out of the edge to help with airflow but is not necessary
I also have dividers in the port that are nearly 3" on long side and around 1.5" on short side. Each side of the cut will have a 45 degree cut so they match up flush with the back wall as well as each other.
Any questions, just ask. If you want to tweak the box, give me time, these things take a little while to get worked up. I wouldn't recommend overpowering the subs AT all in this box, as it's on the large side of what would be recommended and I wouldn't want you to lose mechanical control by over-driving the subs wit too much power.
Crap, I forgot to mention, the overall dimensions of the box are 37 wide, 16" tall, and 23" deep. Sorry for forgetting that but now you have it.
I also wanted to add this for you, in case you were curious. This is the spec sheet on your subs. Yours are the RFR3112s:
Lol, Nah those dimension don't matter. I mean who needs to know them in order to build the box. Just slap some plywood together and call it a day.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Haha, well the diagram was pretty self explanatory. Like all 60s have to do is add the measurements or look at the bottom piece for width and depth. That box should sound pretty mean and be good for lows.
If you have the room for two 15'' Hcca's, i dont jnow why you wouldn't run those.
truthsayer
This could be part of the reason:
They are minty.
Here are the HCCAs:
I'd personally go with the nice 4" coil, minty looking Fosgate. I can't see the detail on the condition of the Orions but I know the condition of the RFs look great and I'd trust running them. The HCCAs look like they've had more use to me, and if so, we may be taking about sagging, dried up spiders and surrounds.
Thanks a million for the design...I'll be starting that one of these weeks my employer
Nis gracious enough to let me work less than 60 hours. Also, as for the reason I'm not going to run the HCCA's is because its a trunk build and my skill level isn't there to be building inside the trunk. But they are mint as well....never seen more than 750 watts and have always been ran in a sealed enclosure.
  • Who's Online   0 Members, 0 Anonymous, 3164 Guests (See full list)
