box design for first time builder HELP HELP HELP
rsfm089
I would like to build a box tuned to 35hz for two alpine type R's 12" 2nd generation 500 watts RMS my useable space is 34l 33w 16h I have a pos planet audio 3000.1 the speakers are bridge at 1 ohm
What kind of vehicle is this going in?
Builds:
Here is a suggestion, subs / port forward, sealed off, check if fits in it's way in before considering building, subsonic filter to 28Hz:
That will fit it will be about about two inches off the seat I can get it all the way forward cause of a bar that's there and I'm not ready to cut my car up just yet since this is a practice run would 3/4 OSB work I have a ton of it laying around at work
Nevermind, Joe X beat me to it.
Builds:
On the cut list it says shared port assembly 18x14.5 the box is only sixteen high I'm a little confused on how that works and thank u very much
If you figured that the top and bottom walls take away 1 1/2" you would be right, any other questions, let me know, if you are doing port / subs back then a slightly different box would be better.
  • Who's Online   0 Members, 0 Anonymous, 5546 Guests (See full list)
