ImaNoob Posted February 27, 2014 Report Posted February 27, 2014 Alright so im installing the 270 alt next week. My question is what battery to run the (+) cable to ? When standing in front of the truck there's a battery left and right. The power being supplied to amps are going to pull from the right battery( well hooked up to the right) but this battery is furthest away from alt, probably a couple feet of wire. The left batery is probably 10 inches from alt Either way both batts will be connected with 0. Does it matter which one, or what would be better ? Am i over thinking this ? lol Thanks.. 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
MECHMAN Posted February 27, 2014 Report Posted February 27, 2014 i would run a negative and a positive to the closest battery. then from that point I would go to the secondary battery 1-888-MECHMAN www.Mechman.com [email protected]
Bump4life Posted February 27, 2014 Report Posted February 27, 2014 in my personal opinion, you should run dual runs from alt to the nearest bat. then dual runs to the next bat which your amps are connected to. then dual runs to back of car. you should also run dual negative runs from alt casing to first battery. and dual negative runs from first bat to second bat if you want minimal voltage drop. especially in a hot engine bay. then if you have a good grounding spot in back you can ground amps back there edit: if you are only running an RF T1500 single runs should be fine. but dual runs would be better after things heat up. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
ImaNoob Posted February 27, 2014 Author Report Posted February 27, 2014 I have 2 of them (1500) Thanks guys 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
