Swordlordboy1234 Posted February 27, 2014 Report Posted February 27, 2014 actually the ELD shuts off the alternator completely. So you would drop to whatever the batteries resting voltage. Most likely between 12.6 and 13.1 (most 12.. And the reason thats not ideal is when the bass hits your alternator will not notice the battery being drained so you might be hurting your batteries and your amp, possibly even sub due to low voltage clipping. Most of the time its not "ANY" accessory for my car. Im not sure if headlights will trip the ELD, but i know that the heater and AC trip it for sure. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
OrzechNJ Posted February 27, 2014 Report Posted February 27, 2014 parking lights did the trick in my case sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
B.E.N Posted February 27, 2014 Author Report Posted February 27, 2014 its my buddies car and his money, so we'll see what we actually end up doing in the end, but I appreciate the info
OrzechNJ Posted February 27, 2014 Report Posted February 27, 2014 I made this video for Singer right after I installed the alt.. I was keeping the parking lights or fan on to avoid it.. sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
Swordlordboy1234 Posted February 27, 2014 Report Posted February 27, 2014 I made this video for Singer right after I installed the alt.. I was keeping the parking lights or fan on to avoid it.. Gas is needed sir. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
OrzechNJ Posted February 27, 2014 Report Posted February 27, 2014 no.. it got broken at some point.. it was showing anywhere from half to empty when I had less than half tank lol sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
