I cant seem to get enough port area per cube
f150on33s
Someone help! lol I cant seem to get what i want. I was hoping to do a 6in aero but for the tuning I dont think it will work. So I tried 4in but the port area per cube i low. Any ideas on what to do? Its for a Soundqubed HDS300 12'' powered by a Audio Technix AT1200.1 at 1ohm. Hoping to tune to 30-32hz.
Here is what i got.
2003 F-150 Single Cab
Pioneer 80prs
All KnuKonceptz 0ga Wiring (all soldered using Sky High Lugs)
Sky High Fuse holders
Big 3 with redtop
Karma SS RCAs
Eclipse EA4000 for Mids
Rockford Fosgate Punch Pro 6.5s
Crescendo RTS-1 tweets
Audio Technix AT1200.1d for Sub
Soundqubed HDS312
Box 2.65cubes @ 32Hz 6'' Aero port
Stock 130 Alt (looking at a Singer 270 Alt)
Well you can either go with a single 6" or two 4" aero ports, in either case you are going to have to put a bend in them to get them to fit. Or you could use a slot port.
Builds:
circle ports are more difficult to get "high" port area and low tuning.
i wouldn't tune a soundqubed woofer that low. try like 35hz.
Would 35hz still do good for decaf?
Is there any reason that your box can't be wider than 15" ?
Yes, its going to be a center console box in a single cab F150.
Pioneer 80prs
Big 3 with redtop
Karma SS RCAs
Soundqubed HDS312
You can do a fully external round port firing sideways, in your type of vehicle you can tune higher and still get a strong low end, 34-35Hz will work for low tuned music.
  • Who's Online   0 Members, 0 Anonymous, 2683 Guests (See full list)
