Using 4ga for an amp with 1/0 inputs?
Okay so had a question, would running 4ga to an amp with 1/0 inputs be okay short term? Or bad. Buddy a SQ 2200 and has 4ga because that's what he was using to run his SQ 1200. Input please.
2001 Chevy Blazer LS
Kenwood KDC-HD552U
2 12" SDC 2.5 D4 Fi SP4 18" 4 Sundown SA-12's
HiFonics BE 1200.1 Soundstream RUB1.2500D Looking for a 5k
XS Power D3100
4 Soundqubed 6.5's (Pro Audio)
2 Soundqubed 3-Way 6.5's
2 Soundqubed Super Tweeters
depending on how long of a run i have my temp rf t2000bd using 4g ofc that is 24" power and ground from the battery. and its been fine. i baby it though because i dont have the electrical to handle it full tilt just gotta keep an eye on voltage
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
I think the run is like 15-17 ft.
Kenwood KDC-HD552U
XS Power D3100
If its good wire and the run is short enough itd be ok. Id want it to be less than say 12 inches tho to pull a full 200+ amps through it.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
with out a 2nd battery? i would not do this reason being full tilt that amp has the capability to draw upwards of 200amps. can your 4g wire handle that kinda load? perhaps but for how long? have u ever seen wire burn do to drawing to much power. its pretty scary now imagine that whole run of 4g under ur carpet doing that. kinda hard to put out when its ran all through out the car. i would get a 2nd battery and 1/0 i would hold off till then
double stuffs
Keeps the gains down until you get the 1/0. Hopefully the 4 gauge is fused correctly just incase you try to pull to many amps though that 4 gauge it will pop the fuse and not burn your car down.
2010 Focus coupe- 8 12" wall. 157.5@46hz
2016 Focus ST - SQ build.
200 amp fuse? or 250 amp fuse?
Kenwood KDC-HD552U
XS Power D3100
I'd say it's worth it at this point to drop a little cash for some 1/0.
I doubt you'd end up melting 4 gauge (unless your termination is shitty) but if you go ahead and do it (we know you will) at least watch your voltage at the amp... or your amp is gonna have a bad day.
2007 Pacifica
  • Who's Online   1 Member, 0 Anonymous, 824 Guests (See full list)
