smalltownbigsound Posted March 6, 2014 Report Posted March 6, 2014 I'm new to running amps that need more power then one battery can do. Just bought a t30001bd. It's pushing a hcca 15.4 wired at 2 ohms. I have 1/0 wire. Stock alternator and d34 battery. I was gonna buy another d34 battery to start and a upgraded alternator. Any ideas or advice? Thanks.
hdorre Posted March 6, 2014 Report Posted March 6, 2014 Do you plan on staying at 2 ohms? The RF outputs what.. like 1500 - 2000 arms at 2? How big is ur stock alt? On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
alaskanzx5 Posted March 6, 2014 Report Posted March 6, 2014 Spending money is the best way to get more from an amp. Check to see what the average stent draw of the car and amp(s) are and check what your voltage drop is like now on music full tilt. From there you can make a better choice. IMO, I would rather be able to produce more power then add more storage. I would get an alt and then Another battery if needed. Don't forget big 3. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
smalltownbigsound Posted March 6, 2014 Author Report Posted March 6, 2014 The amps rated at 2000 rms at 2. I plan on staying at 2 unless I get a different sub, which wouldn't be for a while. I'm not sure about the alt, I'll have to look at it. Im assuming it's rated low because my lights dim bad and my volt gauge in the jeep drops to the red every time bass hits
jarrius Posted March 6, 2014 Report Posted March 6, 2014 Yea get a alt if it's as bad as you say. 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
alaskanzx5 Posted March 7, 2014 Report Posted March 7, 2014 Yep an alt is my vote t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Soccerballzs Posted March 7, 2014 Report Posted March 7, 2014 What year Jeep? Do alternator. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
