Where can I run grounds
All my amps and batts will be in the back of my truck in a toolbox all wires ran already through cab then all power wires ran under the truck and up through the toolbox, where's the best spots to run my grounds there will be 4-6 batts and 2 saz3000s my first guess was run them to the frame and up through it
8 sundown sa 12s walled
Saz3000 at .5
HO alt
All ofc Sky high wire
Alpine components
Rockford power mids
imagesCAA9EA5N_zps0f411022.jpga5ec9a01-b60c-4312-9001-236b48dfe6b0_zpsb01ef146-7fd0-47c3-90e9-f1a2d4595b03_zpsimagesCATNMRMV_zps66a8566a.jpg
Personally i would go straight to the frame. Shouldn't be to difficult.
truthsayer
Ile post one soon I just got all the pics uploading on photobucket I just have to finish wrapping it, I'm on a phone so it takes forever for all my pics to get on there to post on here
Saz3000 at .5
HO alt
Alpine components
Rockford power mids
Drill a hole in the bed and go down to the frame. And it or grind it to bare metal and shoot some paint on it after you make your connection.
Any suggestions on wire to use since it's just ground wires I was gonna head to lowes after work cuz I dnt WANa wait to order any and the local audio shop charges 5 a foot for 0
Saz3000 at .5
HO alt
Alpine components
Rockford power mids
You should use the same quality wire for your ground as you did for the pos. Never skimp on wire, you will fry your shit.
CARS
14 Sierra crew cab daily, Small build coming one of these days
69 C-10 fleetside in many pieces, won't be done till the end of time
Last car '12 Focus with build log
http://www.stevemeadedesigns.com/board/topic/165619-2012-focus-btl-15-crescendo-sundown-audio-control/
Ground to frame and use same wire u used for pos runs. Grind frame to bare metal dielectric grease connections and run a bolt thru frame with lock washer . Then spraypaint connection or use undercoating on them. I would make grounds as short as possible.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
  • Who's Online   0 Members, 0 Anonymous, 4424 Guests (See full list)
