dual alternator, dual battery wiring help.?
Amps in my project -
1. 4000W RMS Mono
2. 1100W RMS Mono
3. 1000W RMS 4 Ch
4. 1000W RMS 4 Ch
Total - 7100W (+ loss due to efficiency)
I am getting
2x "Mechman Universal 320A Alternators" (one with Honda OEM regulator pin, other self exciting)
2x "XS Power D3100"
lots of 1/0 Gauge Wire, terminals & fuses
Is it enough to keep up.?
Attaching A rough wiring diagram. suggest better options
1. 4000W RMS Mono
2. 1100W RMS Mono
3. 1000W RMS 4 Ch
4. 1000W RMS 4 Ch
I am getting
2x "XS Power D3100"
IMO you're on the right track on your setup
I calculated roughly 360 Amps of current at 14 Volts required to play MUSIC at clipping This assumes Class D amplification for the bass and Class AB for the top end.
Double that for sine waves.
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
Won't that be a problem, if one alternator is on OEM honda pin (controlled by ELD).. & second alternator self exciting.?
couldn't that cause voltage difference between both alternators.? What would be it's effect on the system if this is the case.?
  • Who's Online   0 Members, 0 Anonymous, 2105 Guests (See full list)
