can you hear music at all with the knob in? if everything else checks out, the amp might have kicked the bucked :/ it should be working with the knob out
~ If it was easy, everybody would be doing it ~
Yeah you can hear music with it in or out just very faint. The amp shouldn't be bad its never been damaged, overpowered, crossed or anything. The amp is almost brand new still? Could it go bad just sitting in my room?
no probably not from just sitting in your room lol but maybe the knob shorting out could have done something. but if it plays some with the knob in them maybe not? it's hard to tell. i wouldn't put the knob in anymore. sounds super sketch and i wouldn't wanna accidentally blow your amp or sub.
double check rca's and all the settings on your amp and deck with the knob out.
i would unhook everything! start from square one. rerun without the knob and go from there. and do you have a rear battery? if not why are you going all the way back to the battery for a ground?
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
I went all the way to the front because there was already a ground wire coming from the battery because of a dual amp set up so it was there and I figured it was a a gaurenteed ground.
i would take aj's advice and start from square one just my opinion, ive heard nothing but bad things about bass knobs that hook right into the amp , the guy i bought my 2500bdcp off of had a knob in his made his amp go crazy all lights still work but it gets no output have to send it back to rf for a 320$ repair you may be looking at the same issue and getting no ouput out of the amp ?
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
the problem with running all the way back to the battery Is you (most of the time) get a worse voltage drop. the discharge of power takes that much longer! would you rather drink from a 6inch straw or a 3 foot straw? same thing here. I'm not saying it's the problem but it will help. all my grounds are under 3feet.
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
  • Who's Online   0 Members, 0 Anonymous, 319 Guests (See full list)
