Single Kicker L7 15" on a Hifonics Brutus 2400.1D
Rehawk1
Dont get l7s, i had 2 of those 15s on a kicker 2500.1 and they fucking stunk. I blew 2 of them and luckily they replaced them both.. No clip/bass boost, they just constantly smelled like shat.
Ok so what about Orion HCCA 15.2? This is going WAY back but I had a punch 18" in a olds delta 88 when I was in highschool pushing it with a punch 200 and I couldnt be touched, its been a long time since I have seen people pushing 18" and stereo shops here call 15" ancient dinosaurs but I have always ran 15"+. So any good suggestions on what subs to go with? This is going to be a long time project Im doing on my days off from the oilfield and a bonding expeirience with my son while building and hooking everything up I honestly do not care about price i care about quality and well DB! Lol any thoughs?
@Ilikeeggs, um, if you blew your subs, then something is wrong with your setup. I've ran L7 subs for more than 7 years; bangin' it hard and never had a single issue. It's funny, many people claimed that Kicker blew easily. But in my experience with L7's, not a problem. Hm...
No my L7 didnt blow, but when I started banging it hard the amp went into protection mode and im not sure why? But I can see power will be a issue if I went with all hifonics amps
What is your electrical like? Could have low voltage is why your amp went in to protect. Orion hcca's seem to be the new sub a lot of newer people are running besides kicker. There good subs from what I heard just costly because of the name attached to them from what I understand.
Amp wise I would look at soundqubed if you want a cheap amp that will do rated power+
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
My voltage is not dropping below 12.8v now that i threw the 50 farad cap in, again I know ppl do not believe in caps but in this case it helped me. I just downloaded bass heads unite CD and pushed it hard and it did not shut off, Im running 1 alt and 1 batt right now and I think after a long time of pushing it yesterday my alt was getting hot because now its all cold it did not stumble once? My 3 alt bracket should be here wed then Ill have to figure the best place to order those, I have heard all good about mech man possible 3-300 amp would be a good start?
hifonics amps are horribly inefficient. not worth it.
why cant you just get one or two good large amps instead of getting a bunch of smaller "meh" amps. you're going to have a hell of a time gain matching and making sure all the settings are identical on each of the six amps.
edit: also, why l7's? if you're strapped for space, go with something else that doesn't need an olympic stadium for a box.
Ok cool, ill check those out. I have no problem going with 2-3 huge amps and different subs but even to fit 4 will take a mammoth box im in the decision phase right now and the only for sure thing is power, i know im going to need a lot of it so that ball is in motion, what subs should I consider?
  • Who's Online   0 Members, 0 Anonymous, 8802 Guests (See full list)
