is there a way to calculate per channel...
Inspiron100
my friend gave me an old amp because he got a new one.
http://www.drdetailshop.com/250.htm
it says:
250 watts RMS bridged into 4 ohm
but, i was wondering if there is a way to find:
? watts RMS bridged into 2 ohm
I'm wondering because with he box i made, I wired the subs to 2 ohms.
Its safe to assume that because there will be less resistance the wattage will increase but I'm curious as to how much that 2 ohms will matter.
thanks guys
Bridged into 2 ohm will be poof and probably fairly quickly
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Amp isn't rated at 2 ohms bridged because it isn't stable at 2 ohms bridged. By wiring it to 2 ohms bridge you do the following:
You void the warranty of the amp, put the amp in a situation where it is working too hard to supply power, creating extra heat within the amplifier, creating an additional source for the possibility of an electrical based fire, putting you/your car/your passengers at risk.
  • Who's Online   0 Members, 0 Anonymous, 582 Guests (See full list)
