gibblegeibel Posted March 15, 2014 Report Share Posted March 15, 2014 i ordered 2 skar audio vvxv2 10's i need help designing the box for them here are my maximum deminsons (inches) to work with height-16.5 depth-11.5 width-42 i would like to get it tuned to 32 hz. can some one plz help me with this deign. i used skars recommended box design and tweeked it better to fit my car. but i can use there design. i want to see if can get my deminsons to work. Link to comment Share on other sites More sharing options...
Joe X Posted March 15, 2014 Report Share Posted March 15, 2014 This is for a trunk car, subs / port forwards/backwards, figure is only an assembly guide, amp subsonic filter to 28Hz: Link to comment Share on other sites More sharing options...
gibblegeibel Posted March 15, 2014 Author Report Share Posted March 15, 2014 it is going in the trunk of a car. I was planning the port and subs to face the passenger compartment of the car Link to comment Share on other sites More sharing options...
gibblegeibel Posted March 15, 2014 Author Report Share Posted March 15, 2014 was that box designed for 2 subs? i was just wondering since i only saw 1 hole cut for a sub. Link to comment Share on other sites More sharing options...
Joe X Posted March 16, 2014 Report Share Posted March 16, 2014 Here's the dual sub version BUT goes above your max depth, had to limit width so that can fit through the trunk opening, building a cardboard dummy box would be needed to test fit before attempting to build: 45s are 2 1/2 wide except the one inside the port brace is 1" wooden dowel rod. Power to subs: around rated power. Link to comment Share on other sites More sharing options...
gibblegeibel Posted March 16, 2014 Author Report Share Posted March 16, 2014 I plan on running a 1500 at 1 ohm Link to comment Share on other sites More sharing options...
Joe X Posted March 16, 2014 Report Share Posted March 16, 2014 Power is ok, if you had even more depth I would probably go for port in the middle which I like better, if not then like the above. Link to comment Share on other sites More sharing options...
gibblegeibel Posted March 16, 2014 Author Report Share Posted March 16, 2014 i was trying not to lose all of my trunk space. how about an areo port design? Link to comment Share on other sites More sharing options...
Seymore Posted March 16, 2014 Report Share Posted March 16, 2014 For two 10's I'd go with one 6" port in the middle or two 4" ports on either side or the middle. If you're using areo ports, then you can just mess around with torres calc and get a good idea. 2001 Civic LX SedanPioneer DEH-7500HD Big 3 in 1/0 Knu CCARockford P500-4RF Punch P165-S in doorsRF Punch P165 in rear deckFront doors deadened with DamplifierNextSQ's new HDS208 8" in a T-line whenever it FINALLY COMES OUT I CAN FINALLY AFFORD IT Bend over and I'll show ya. how is it 2 days work? half a day at most, i may be an idiot, but im not an idiot. Link to comment Share on other sites More sharing options...
Joe X Posted March 16, 2014 Report Share Posted March 16, 2014 i was trying not to lose all of my trunk space. how about an areo port design? Those are pretty higher displacement subs, you could manage to cut 2-3 inches with a turning or side firing 6" round but you'd compromise efficiency IMO not worth it. There are many ways to lesser box size if you don't mind losing efficiency. Link to comment Share on other sites More sharing options...
