Ditch your factory air box and go to an intake that air box takes.o
up so much space and for no reason
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Thats how i have had it for years, i dont use the cover..Once im done with this build im probably going to do that, along with fixing some of the paint..
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
What max demensiona did you come up with? I have the same truck and am pulling my back seat out as well
Max of what total space ? For the box it was like 50 ish inches, before it hit the brackets the seat mounts to. You could get more if you made a platform above the bracket, but loose box height if your keeping around window line..There is a ton of room with the seats gone...Let me know ill grab some exact measurements for ya..On a side note if your removing rear seat belts be extra careful removing rear panels..
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
The Big 3..Looks bad, just waiting on Battery's and terminals to show up . So i can tidy everything up.Sky high wire is beast... And started wiring the amp rack up, Its fuckin cold out though..17F isint working for me
Do you guy think a piece of white plexi on the bottom of the amp rack would look stupid with amps mounted on that, i will have a cover with clear plexi for a viewing window..I want to light the rack up with blue leds...Looking for your opinions though.I think the white would reflect the blue leds nice, just not sure with black amps mounted ..
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
You know you can pull the bracket right. I tore the whole thing out of mjne. It took longer to do that then just about everything else I've done but it can come out
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
so much more room that a single cab... I have a huge Power Acoustik Demon 6000.1 under my bench seat, and no legroom what so ever, but it slams! My buddy just bought like all my speakers so all i have is the subs, kinda funny listening to just bass and no music!
Knowledge is the greatest tool in any garage. It's also the most priceless, and most easily shared. icon_nuts.gif
Here's my latest build.
http://www.stevemeadedesigns.com/board/topic/181273-89-c1500-build-log/
I dont even remember what it looked like behind the plastic, did this when i first bought the truck..I wish i would have removed it though....At this point its not worth taking the plastics out again...op might want to remove his though
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
http://www.gmt400.com/forum/showthread.php?18965-1998-C1500-ExCab-Blue-Int-White-Ext
Man here's my build when I still had my 98 silverado, I pulled out the back seat and built a box, tuned the thing down to 20hz with 2 p3 15's in there, man she hit hard lol!
Nice Build.. My 3rd brake light fucked up like that to, not sure what happened but it was leaking water into the cab.
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
