Thewes Posted March 14, 2008 Report Share Posted March 14, 2008 So I finally bit the bullet today and decided instead of having half my gear sitting in my room, Ill make another attempt to hook both subs up. So I wire up the second sub just like the first (D2 coils, wired down to 1 ohm) and then when I went to install the other amp, realized I didn't have a torch so I couldn't solder the connections. Not a biggy, so I threw the sub in anyways, and figured might as well see how this one sundown will push both my subs. Well it hits, it hits really hard. My question is how the fuck is it moving both these subs, it must be running at .5 ohms right? I'm a bit uneducated on ohms law, so some help would be great. Thanks. Link to comment Share on other sites More sharing options...
pimpedout97x Posted March 14, 2008 Report Share Posted March 14, 2008 i will vouch. its loud. Link to comment Share on other sites More sharing options...
pimpedout97x Posted March 14, 2008 Report Share Posted March 14, 2008 it is @ .5 weston. 1 ohm each, then u have both paralleled to the amp, 1 + 1 in parallel = .5 Link to comment Share on other sites More sharing options...
Stephen Posted March 14, 2008 Report Share Posted March 14, 2008 Please make sure you have PLENTY of power going to it if you are running it at .5. I dont think it is safe for that amp to run that low, but if you do keep your voltage up. you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER Link to comment Share on other sites More sharing options...
Thewes Posted March 14, 2008 Author Report Share Posted March 14, 2008 it is @ .5 weston. 1 ohm each, then u have both paralleled to the amp, 1 + 1 in parallel = .5 Yeah megalo said it is internally bridged so I think it is running at .5, but how much power are the subs seeing? They are actually not even getting warm, as compared to when I was just running 1 the cone was getting hot after a good session of jamming. Link to comment Share on other sites More sharing options...
Thewes Posted March 14, 2008 Author Report Share Posted March 14, 2008 Please make sure you have PLENTY of power going to it if you are running it at .5. I dont think it is safe for that amp to run that low, but if you do keep your voltage up. Voltage never goes past 12. Link to comment Share on other sites More sharing options...
qu1cks1lver56 Posted March 14, 2008 Report Share Posted March 14, 2008 that amp might get hot at .5ohm id be careful First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load. Link to comment Share on other sites More sharing options...
Thewes Posted March 14, 2008 Author Report Share Posted March 14, 2008 that amp might get hot at .5ohm id be careful Oh it got warm for sure, but I am just keeping it to short jammings for the time being. The sundowns do have thermal protect though right? Im worried, I knew it was too good to be true. Link to comment Share on other sites More sharing options...
qu1cks1lver56 Posted March 14, 2008 Report Share Posted March 14, 2008 i dont know if they have thermal protect or not. but like stephen c said keep the voltage up and dont let it get too hot and you might be alright. rig up some cooling fans? lol First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load. Link to comment Share on other sites More sharing options...
Thewes Posted March 14, 2008 Author Report Share Posted March 14, 2008 i dont know if they have thermal protect or not. but like stephen c said keep the voltage up and dont let it get too hot and you might be alright. rig up some cooling fans? lol Just got that full tank tonight, putting the rear AC on BLAST. Link to comment Share on other sites More sharing options...
