LemonyGuy Posted March 19, 2014 Report Posted March 19, 2014 I'm getting an Audioque SDC2.5 15 and will be needing a box. I made a box in RE Box calculator but I was told on another forum that RE isn't the best for box designs. I'm good with wood so building is a problem but this designing thing is way over my head. I heard you guys can help my dilemma. The max the box can be 17in high, 24in wide and 34in long. If the sub was mounted on top then it would have to be dropped to like 15-16 cause 17 is close. Also what is good amp that runs 600 watts at 2 ohms? Right now I'm looking at JBL gto amp that puts out 500 at 2 ohms. This one to be exact http://www.amazon.com/JBL-GTO-501EZ-Watt-Calss-Amplifier/dp/B007GYU71K. My budget for the amp is tight atm to around 150. Thank you in advance.
BoomZoom808 Posted March 19, 2014 Report Posted March 19, 2014 I would start here. I have built a few of these boxes and they never did me wrong. They have box plans for a 15 http://www.ddaudio.com/support/box-plans Also downloading the Torres calc will help out a lot. 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
Joe X Posted March 19, 2014 Report Posted March 19, 2014 Based on the information you provide ( the assumption is that you have a trunk car and you need to build a cardboard dummy box first to make sure it will fit in it's way inside), you could do this: sub /port forward or backwards, ok with the power you have:
LemonyGuy Posted March 19, 2014 Author Report Posted March 19, 2014 Thank you Joe! That is perfect! Only question, where is the measurements for the little angled pieces on the inner corner of the L and the outer corner of the port? Once again thanks a ton! If you lived near me I would definitely owe you a 6 pack!
Joe X Posted March 19, 2014 Report Posted March 19, 2014 Sure, the important thing is that the 45 inside the port is made in a size that allows the port width to be the same as the rest of the port, the 45 outside the port is 2 1/2" wide, if you can't do 45s well better don't do them, specially the one inside the port, it could actually hurt performance if it's too big, here is a pic:
LemonyGuy Posted March 20, 2014 Author Report Posted March 20, 2014 Thank you, thank you. Also make the 6 pack a case with a nice burger, music would be pounding in the background.
Joe X Posted March 20, 2014 Report Posted March 20, 2014 Happy building! Any other questions let me know.
