!!!!!Box design help!!!!
If doing a wall you have to make sure you plan everything prior to start, most important is understanding the wall building process, failing to do so can result in trashing your vehicle interior and getting bad results.
I understand that and I'm not shooting for numbers or anything... Just want something more then what I have now but have to basically build a huge box/wall to do so.. Plan is to have batteries under the enclosure if possible so can only be 33" tall to do so... If not then there's a plan b but just need a design to work with just to get me started in the right direction
So I just remeasured my space available..... If I go 38.25W x 33H x 18D (allowing for double baffle) that gives me an internal volume of 10.55 cuft before all displacements. Is this enough for me to run 2 15s with a top slot pot facing forward (wall)????? Can someone help me with a design
The Sundown Zv3 18 only needs 4 cubes net. You're close and SHOULD have enough for those after port displacement. I didn't run any math on your numbers, only assuming you got 10.55 net correct.
For space analysis ONLY, take a look. It's double layer 0.75" all around, you seem to have the space:
  • Who's Online   0 Members, 0 Anonymous, 3139 Guests (See full list)
