Im about to order some components and run them from my 4channel, now if i do this str8 up then ill be running passive?
Which means i cant control what freq. im putting into the speaks because the crossovers take car of that>?
Or does it matter what type of components i have?
You will be able to alter the frequency by the Xover on your amp. Shouldn't matter what components you get.
Head Unit: Pioneer DEH-P4050UB
Subs: 2 Pioneer Premier 12" ts-w3004spls
Sub box: 3.2ft3 tuned to 35hz
Sub Amp: SoundMagus DK 1800
Speaker Amp: Rockford Fosgate 200a4 Bridged to fronts
Front Speakers: DLS MS5A components
2 gauge power & ground
you would run just the raw drivers to the amp and toss the crossovers that are included aside
So id put the mid on one channel and the tweet on another?
And another question, if i put the amp's x-over on full, does that mean i control both low-pass and high-pass?
Example: Amp's Crossover on Full
Low Pass- 250hz
High Pass- 50hz
If I do that then does that mean my speakers are gonna play 50-250hz?
if you put the amp on "full" that means "fullrange"....it will amplify everything. IMO, if you want to go active, get a processor of some sort to make SURE each speaker is getting the frequency it needs and nothing else. In other words you dont want tweets playing 60hz, and you dont want your subs playing 2500 :D
Follow my Tweet (Twitter)
Guest MegaloManiac
Low Pass- 250hz
High Pass- 50hz
if you set amp to full xovers are disabled on amp and are running fullrange. usually when one does this they signal is already xovered before it hits amp.
Alright thanks guys!
So running basic passive setup, lets say my mid on my components can go to 60hz, so im thinking set my amp on high pass around 70hz and then the components crossover should take over from there right?
