Power issues
Just the 3 yellow tops in the back, one run of 1/0 run to the back and batteries in series with three frame grounds. Also have 1/O from the alt to the distribution block under the hood
that might be part of your problem right there....
You need to do big 3 in 1/0
Buy another yellow top or the biggest xs batt that will fit under hood.
That is where I would start
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Who makes your alternator?
Thanks guys, I'll test them all individually tomorrow. It does it when I'm at an idle, it helps to rev the engine, but it still drops voltage. I'll get the alt tested too just to be safe. The alt is putting out 13.70 with the system off and truck running, I feel like a dumb ass that I didn't realize that was why the batteries were reading that, cause the truck was running. Haha but thanks guys, I'll update when I test everything tomorrow
What make of alt do you have? Just cause it is a 300a alt doesnt mean you get 300a. And now you say it does it at idle, for all you know the alt could do 100a at idle which cant power a bullshit system, but at 2000rpm it could make the 300. WHAT ALT DO YOU HAVE (MAKE, MODEL, ETC)???????????
I'm not sure what brand it is, I bought it from a buddy of mine but I'll find out tomorrow. What exactly is the Big 3 upgrade? I've heard people talk about it but not sure what it is
Big 3 (important cables in your charging system)
1. Alt charging wire to Front battery
2. Battery ground to frame
3. Battery ground to engine block ground (or grounding strap)
It should be done in 1/0 OFC wire.
http://www.stevemeadedesigns.com/board/topic/13280-how-to-do-the-big-3-tutorial/
Right there read thru this thread will explain it very important in a system. One of the first things I do in a system.
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
