Pretty sure its not going to be a fuel issue since you can start it back up right away. I just had a car the other day do this. It would drive fine then once you came to a stop the car would stall and start right back up. Put the car in gear to go and die. After 10 hours of testing and talking on the phone with the manufacturer ( im a tech at a dealer) , we both came to the conclusion that the torque converter clutch was sticking. This was not GM though.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
Appreciate any input bro, I want to get this ride driving before I end up waisting more money or having to buy a next ride
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
Im no gm tech but ive owned a few gms im my life and i know some of their problems . To me It sounds like a fuel/air ratio problem..either not enough air or fuel in the system ..or a faulty sensor..ive seen this happen when mass air flow sensors go bad..ive also seen it happen when iacv goes bad ..or could be the throttle needs to relearn the throttle open/ closed position.. but these should all throw a trouble code...to tell the truth this needs an experienced mechanic with scanner machines. If theres no trouble code could be the pcm is erasing them on its own in that case it would mean you need a whole new computer.. right now most gms within that generation are having alot of problems. I had to rebuild the engine on my 04 impala ..and pretty much replace the whole front end suspension as well as a rack and pinion..and I still need all four shocks..so good luck man
You need trunk space to get groceries and shit...bitches love groceries
on mine grandparents suv it didn't throw no codes on the throttle body I just knew it was it had no power and almost stall we change it took it to dealer they program it working like a charm
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
