questions on sealed off trunk
sbg
Thinking of putting my subs in my 2nd car. A 01 focus with the fold down 60/40 back seats. Would be sealed off setup. I have a question about it, I have a car seat I keep in the car on the 40% side. If I seal off and only have the big side of the seat down all the time is it not going to work right. Like if part of the port and a sub is blocked by the other seat. Or should I make sure the port is not blocked at all? Thanks for the help.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Bump
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Id try not to block the port or sub(s). How much distance would be between the port and seat?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Do not block the port at all, and block as little of the sub as possible. Hopefully the 60 side is the driver side.
Yep 60% side is on driver side. I don't think I can get away from not blocking a sub off.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Pics of what I'm working with. Only 25'' w
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Cut the baffle so the sub is right next to the port. You will still have plenty of output even if a bit of the sub is blocked.
Its going to be 2-12" hdc3
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
I have a box right now, center port. 35" w so one sub and the port and a few inches of the other sub would not be blocked off. I just don't want to seal it off if its not going to work in the way it should.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 3225 Guests (See full list)
