XS Power
There's an XS that will fit in, & work in nearly every application.
What is a "96R"?
EDIT: My bad, ... 96R = a BATT type? If so, just match up specs ... A little more here or there does not hurt.
Edited by Sutliff
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
Would a group 51r fit? Go out there with a tape measure and double check. It's perfectly acceptable to get a new tiedown and remove the stock battery insulator/cover to make things work. For example my own car, original battery was a group size 35, but I managed to fit a group 34 battery in there. Had to remove the cover and stock battery tray to make it work
51r:
Length – 9.04 in
Height – 8.19 in
Width – 5.43 in
I think that might fit. I'll have to check in the morning, I'm not home right now. But if I were to throw an xs D5100 up front what should I throw in the back?
I'm trying to run alpine MRX-M240 @ 2,400 watts, 2 alpine type Rs on 1/0 ga.
What does your voltage drop look like now? Have you done the big 3?
If it were me, I'd start by doing the following:
Do your "Big 3"
Upgrade your front battery
Check over said shop's wiring - make sure connections and grounds are up to snuff
Possibly replace said shop's POS wire
Invest in a volt meter of some sort and hook it up to your amp. That way you know what voltage your amp sees. It's a very powerful tool to have and will come in handy for both diagnosing on the fly and insuring the health and well-being of your amplifier&electrical
I like to "play it by ear"
With a volt meter, you will know what you drop to. From there we can make the decision of whether or not you even need a secondary battery
  • Who's Online   1 Member, 0 Anonymous, 757 Guests (See full list)
