Any way to safely wire 3 subs (SVC I believe) to a mono-block? I know I can wire them to a 6ohm load but is that all? I'm still learning so bare with me.
Ive decided this is what I'm going to go with as long as CF provides with my trunk. I'm doubting it will but a man can dream.
And when it comes to the Sundown Audio SA15's - SA12's D2 v the D4 What's the difference? RMS seems to be the same.
Ill update this thread when/If I manage to get the stuff I need and I will post with updates as this will be my build thread unless I change my mind on the setup. Im still working on power upgrades atm.
Edited by Cadillac_Fresh
Difference is the resistance in the voice voil one is dual 2ohm the other is dual 4ohm
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Won't be enough power. Just run 2 instead of 3. 3 d4 will be 2.6 final load. And 3 d2 will be 1.3 final load.
Easier an better jut doing 2
Makes sense, Cheaper to :good:
if you have room go for 2 15's
You think that amp will be sufficient enough to put enough power into the 2 SA-15's?
  • Who's Online   0 Members, 0 Anonymous, 2884 Guests (See full list)
