the blinker light on means a light is out on that side somewhere check all the lights up front .
the 80s s10 and our 93 s10 do that when a bulb is out most of the time its a blinker/running light bulb
yes It might be I think I heard this before I will try it tomorrow. thanks
Check Out My 1986 Chevy Caprice Brougham Classic Restoration:
http://www.stevemeadedesigns.com/board/topic/184647-1986-chevy-caprice-restoration/
Jordan, cool to have a member from Jordan :)
How are you planning to restore the car? Like as it came from the factory? Or kind of custom with your own touches, fixing and improving things along the way?
The turn signal is on a relay, it's probably defective. Find it and replace it, problem solved. Temp gauge can be replaced with an aftermarket fairly easily.
I guess since you are on an audio forum, you plan to upgrade the stereo system in the car too. So the v-belt setup will have to be replaced in favor of a serpentine belt setup. Well, not necessarily HAVE to be replaced, but it opens up options on a charging system more than with a v-belt.
thats kind from you, Im planning to get it back as it was when we first bought it, I mean It runs smoothly and its clean from the out/in side.I will see if the relay is down but I will check the previous guy method first.
Yea I will look for v.belt in futrue.
and the wipers.check for a ground strap/wire going to the wiper motor. i know on some fords if that ground gets messed up the wipers wont stop.......if all else fails try a new ignition/key switch. good luck
God damnit man you are so true, today i saw a black wire hanging of the chassi just by the wiper motor, I will put a new one because I cut it off.
Nice. :) I'll be watching.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
fixed the turn signal/light handle solved the wipers-blinker.
This is the bolt/screw I was talking about.
The fuse box is a little messy
got that broken mirror out
Cleaned these parts in my house
This was broken
Done
Removed this back shit
Gotta love this light
Im thinking of replacing the steering wheel but idk about it yet
Couldnt work much today even though I have a holiday today cuz im sick.
I would love to work on a car like this. I love cars around this age.. I would really love to work under the hood. Old chevys are great to work on! Looks like your doing a good job so far. This vehichles got my attention. for the shape it was in I really wanna see this thing fully restored
"Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21
PIONEER DEH-P8400BH
2 CROSSFIRE C5 1700D
2 CROSSFIRE C7 18
HOOD. NSB GROUP48 TRUNK SMS AGM400
DUAL RUNS X SCORP 1/0 OFC
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
I went to the roof shop and told him to make me a custom inside roof, I will be putting it in tomorrow if its done, It will be leather and same as the interior color.
The seats are really bothering me, please if you know how to remove them tell me.
I discovered some problems In the car and I would like to get some help:
The left turn signal on the dash board is stuck (green arrow) and not blinking but when I turn it on It goes normally on the dash, another thing thats the temperature gauge is stuck at 100 as you can see in the pictures, and the windshield wipers keep going on and I cant stop them. thats all for now ,
Also I had a trouble with removing the back seat (back) theres a screw down there but when I try to take it off it keeps spinning ... so I couldnt remove it.
umm about the front seats, I couldnt remove the driver seat because I couldnt see the screws at the back I did the front 2.
The temperature gauge stuck at 100, if it was me I would change the thermostat and flush out the coolant system and see if that solves the issue. I am not a certified mechanic but I have been working on my own cars for along time. The front driver seat try moving the seat all the way forward and look for 2 bolts on the back like you found the 2 on the front, there should be 4 bolts holding the seat down. The bolt on the back seat, if it keeps spinning there is obviously something on the other side of the bolt preventing it from coming out, a nut a washer a clip or something. Can you access the other side of the bolt on the backseat? Worse case scenario I would get a dremel and but the bolt and just put a new one on.
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
In this video this guy is showing that theres a wire thats goes under the engine, its for the gauge I flushed the coolant just before I start the car about a week ago.
I will look for that wire tomorrow, and about the back seat I will get a good light to look down there, yea I think theres a washer behind this bolt I can hear it hitting the chassi but as you said its not bolted to the trunk, its under the car, under the exhaust under every thing....
I will drill the bolt out if I had to.
thanks. :)
