Tuxer Posted March 26, 2014 Report Posted March 26, 2014 Hello everyone, first post and of course it's going to be a question seeking input... I've got a 2001 Tundra w/ Access Cab and looking to add a sub to the mix. I've decided on the Sundown Audio SD-2 8" for it's size, mid-shallowness and capabilities. I don't have space under or behind the back seat. I thought maybe the small space between the center console and back seat MIGHT work. What are your thoughts? The sub would be facing up (or I'd like it at an angle facing the front if possible). Height is going to be the variable in the equation. I've only got 9" deep (between console and seat) to play with and 9" wide as well. I might be able to go 10" wide depending on how tall. The box would need to be sealed per SA's recommended .25 ft cu. SD-2 8" Specs... Sealed .25 ft cu recommended Displacement: .07 ft cu Depth: 4.75" Outside Diameter: 8 3/8" Cut-Out: 7 3/8" Thank you in advance for the input!
n8ball2013 Posted March 26, 2014 Report Posted March 26, 2014 Down firing would probably be the most optimal in your vehicle to be honest. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Tuxer Posted March 26, 2014 Author Report Posted March 26, 2014 Hadn't given that option a thought. I was hoping the box wouldn't have to be above 9" as that's the height of the back seat and center console, that way it could be somewhat even and not horrid looking. Likely would have to add half an inch to accommodate excursion. The area between console and seat is my number 1 choice, and if down firing is better (makes sense now that I think about it)... gotta do what you gotta do. So let's see options with it firing down. Thanks n8ball
john253a Posted March 27, 2014 Report Posted March 27, 2014 Another one I like to use is the kicker cvt8 Not as good as the sd but well worth a look into if you need a small space filled
