advice for car audio noobie
x2 on not using a terminal cup.
2 ways to do it that are better than terminal cups.....
1 way, which I have done but it isn't my favorite, is to drill 2 holes, just big enough to run your wire through. 1 hole for positive, 1 for negative. Be sure to tie knots in the wire inside the box so if the wire gets pulled on accident it doesn't yank on the sub. Seal the holes on the inside of the box.
The other way, which is what I would recommend would be similar (minus electrical tape) to the example in the picture in post #72. Drill 2 holes, put a bolt through each one with the head of the bolt on the inside of the box with a washer. Put the ring terminal that you soldered or crimped onto your speaker wire between the bolt head and washer. On the outside of the box, same thing, washer; ring terminal; nut.
Parts-express.com
^This
This place is amazing
New to the car audio world and looking to learn as much as I can.
Home depot, ace Hardware
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Heres what i used for my last box got them at home depot
Hope this helps you a little
Silicone both sides to seal everything up good
Washers inside and out side of box then 2 nuts on outside of box
