box help
sicklife17
The bend in the port is needed to get the tuning that you desire. If you were to shrink your current enclosure, the port would need to be LONGER to keep the same tuning, unless you also shrunk down the port size.
04 Honda Accord LX Sedan
Kenwood Excelon X998
XS Power D3400
XS Power D1200
Singer 275A alternator with factory bypass
64 sqft SecondSkin Damplifier
Build to be decided
:peepwall:
Ok so I think if I go down to a 1.5 inch port that's 9in long in the back if I'm correct it wil bring me to about 33hz. Now if I'm correct te lowere the hz the harder it hits right?
If you are using Joe's box that would give you 13Hx1.5W=19.5sqin of port, much too small for the SA-12. If you're using the one you mentioned above, that would give you only 22sqin of port. I'd aim for a bit more than that.
How hard the system hits is dependent on more than just tuning. Lower isn't always better.
XS Power D3400
XS Power D1200
Build to be decided
:peepwall:
Get 2 SA8s for the airspace you have. It will have a better outcome than trying to cram a 12 where you don't have room.
A single DC Audio 12" would work well on those dimensions, those only need 1.5-1.75 cubic feet to work well.
  • Who's Online   0 Members, 0 Anonymous, 4973 Guests (See full list)
