Rck'nRF Posted March 30, 2014 Report Share Posted March 30, 2014 OK, this may be a little pissy of me,but this is one thing that drives me nuts!! Why does my all time favorite amp company/Rockford/all other good amp makers always design the input Negative and Power right there beside eachother just waiting for a disaster to happen..i mean i tighten shit down good,but the my 4gauge power was starting to work it's way loose,and it's a good thing i re-check shit every so often... My rants of today: 1. PUT Negative & Power sections ON OPPOSITE CORNERS OF your high end AMPs! 2. Make some kind of shield covering OVER your Remote pins!! My remote wire got bent/pulled right over and contacted with the amp body/grounding remote pin!! This is insanity,make sure you tape up/etc your joiners to your remote sections,in case of amp body contact, This stuff SHOULD be in ALL manuals! Link to comment Share on other sites More sharing options...
hazestorm23 Posted March 30, 2014 Report Share Posted March 30, 2014 I think it all comes down to neatness in your install I always check how far the wire can go in the input and then strip it just about the same length just a tad bit shorter and secure it nicely and I never have problems with it or be scared that the will become lose. Link to comment Share on other sites More sharing options...
DubNDodge Posted March 30, 2014 Report Share Posted March 30, 2014 I mount my amplifiers securely and I also make sure my wires are secured to something solid before they are screwed into the amps inputs. If you are careful there is no reason to worry. Unless you just throw shit in the trunk and let wires lay everywhere and call it good. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult. Link to comment Share on other sites More sharing options...
