Underrated Amps!!
mtxcivic07
I'm interested in power rating from amps @ 12.5 V  That way anything higher will yield more power.
but more heat will be created...
What I'm saying is most companies advertise their power at 14.4V. But I want to make sure that enough power is available AT 12.5V and then some with 14.4.  Feel me?  ;)
you must bang with ur car off i guess right?
cause the 14.4 rating is the voltage most cars idle at while on
I don't bang with my car off. But your voltage drops when you bump. Plus I'm running my stock alt. still and my voltage can drop really low (11-ish)
Kind of just a random ? I guess, but I was looking at the amp originally mentioned's specs and it says 600 rms and 1200 peak power... MTX civic was talking about how his peak power was so high but I dont understand... How often will he actually see near that power w/ that amp?
Thanks,
Andrew
doesnt say peak on this page, unless u looked it up. it can see peak more often than u think.
Thanks,
Andrew
yeah everything i stated is all RMS watts there is no peak
18's in a wall to come....Its not all about the posts....check the member #...
My RF T3001bd is rated at 3750 @ 1ohm.
Official Scores at the Dash. and YES. My Bass Boxing is louder than Burp! - 155.5 DB Drag Burp- 155.6 - IASCA Bass Boxing on music (30 seconds straight) sealed up Builds 1. The Acura Integra build = http://www.stevemead...s/page__st__6802. BLK SIN Build = http://www.stevemead...w-pics-10-6-07/
Guest Brett32324
ROckford amps are underrated IMO. my friends 120 watt rms amp pushed like 200 watt rms 12"s. my 1500 watt max power amp can push like 4 twelves each 300 watts RMS. and the amp said 500watts RMS. rockfords are crazy.
with RF you always ge more than what you paid for.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   2 Members, 0 Anonymous, 1298 Guests (See full list)
