mtxcivic07 Posted November 22, 2006 Report Posted November 22, 2006 My MTX 7801 Amplifier is rated at 400 watts @ 4 ohms 800 watts @ 2 ohms 1200 watts @ 1 ohm. This amp is dramatically underrated... just check it out for yourself. in addition to this i Know that kicker underrates their amps as well... what other companies seem to always underrate their amps?? :^ 18's in a wall to come....Its not all about the posts....check the member #...
ChevyBoy Posted November 22, 2006 Report Posted November 22, 2006 i kno i had a kicker that was rated at 350 and put out i think 378. my mtx 801d was said to push 500@2 ohms on 12.5 and put out 597. question though. since thats a 20% increase, u think at 14.4 instead of it pushin 800, its pushing around 960?
cornfed Posted November 22, 2006 Report Posted November 22, 2006 Rockford Fosgate Power series amps are under rated, too. :^
Grtrat1 Posted November 22, 2006 Report Posted November 22, 2006 Yep my RF T10001bd is rated at 1000w @ 1ohm, the birth sheet says 1489w @ 1ohm
mtxcivic07 Posted November 22, 2006 Author Report Posted November 22, 2006 i kno i had a kicker that was rated at 350 and put out i think 378. my mtx 801d was said to push 500@2 ohms on 12.5 and put out 597. question though. since thats a 20% increase, u think at 14.4 instead of it pushin 800, its pushing around 960?yes there is a good chance that it will be getting close to 1000 especially at 14.4 volts. . MTX amps are massively underrated. if you give plenty of voltage there is a great chance of a huge wattage increase 18's in a wall to come....Its not all about the posts....check the member #...
ChevyBoy Posted November 23, 2006 Report Posted November 23, 2006 i mean just cause it was underrated at 12.5. will the percentage that it was underrated there be the same percentage it was underrated at 14.4?
Dale Posted November 23, 2006 Report Posted November 23, 2006 What about Mmats amps? Aren't they underrated too?
dmanson Posted November 23, 2006 Report Posted November 23, 2006 yeh mmats are underrated too. anyone know about hifonics amps? 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
cornfed Posted November 23, 2006 Report Posted November 23, 2006 yeh mmats are underrated too. anyone know about hifonics amps? From what I have heard they are not.
mtxcivic07 Posted November 23, 2006 Author Report Posted November 23, 2006 yeh mmats are underrated too. anyone know about hifonics amps?yeah. hifonics are usually overrated.... usually alot. except the xx-series amps they are usually close to true wattage 18's in a wall to come....Its not all about the posts....check the member #...
