Help... Amp lights dimming not producing bass
Quan804
Wtf.... Just checked everything when I got off work... The fuse holder near the battery has melted off... Smh could be worse
thats caused by loose connections. that could've ended up much worse. cheap fuse holders can cause melting too, but typically its loose connections.
loose connections = resistance = heat
I just fixed my melting problem. Luckily I caught it before it ruined my amp completely. My problem was that I tried to get too much from my amp.
I think I did the same exact thing.. I usually don't use the bass boost on the amp but I was trying to get the most out of my amp since my subs needed more power... Right now I have 2 comp r's 800rms a piece and the stats on my amp puts out 800rms at 2omhs.. Smh only 1side of the fuse holder was melted the side closest to the battery was fine.
Bro I have no idea what would be wrong with it. Could be loose connection....uhh is your battery dying even after your car is off...say u go into the store is it dead once you get back out. If so get a toggle for your amp. My bro-inlaw had to for his cavalier :/ idle man but goodluck
Also, could be your alt died.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Glad you found the problem but just to clarify...
If the battery will start the vehicle with no problem, then the battery is sufficient to supply the amplifier and to be sure, to power the memory on the head unit.
Since you never complained that the vehicle wouldn't start, condemning the battery is NOT the first step in troubleshooting.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
  • Who's Online   0 Members, 0 Anonymous, 677 Guests (See full list)
