01 focus sealed off(vid on page 4)
I prefer the zetec dohc. Still not a bad engine though. see them break the 200k mile marker all the time.
This one only has 50k on it:) and is a 01
in that case as some advice, around 100k miles pay attention to wheel bearings. Rear are easy, 30-50 per side for new drum with bearing and nut. Front replace the bearing and hub. Its roughly 50-70 plus about 40-50 to get it pressed if you take the knuckle off and bring it into a shop. Or else its parts plus roughly 150 per side up front. The knucke is 4nuts/bolts plus taking the caliper and wheel off. Did my fronts in under 1.5 hours per side not including drive time to the shop to have it pressed. Rears I had done in under 30min except on the driver side. When I was trying to get the drum off it cracked. Some how the bearing somehow attached to the spindle completely. Took the whole spindle off and replaced it. Was 20-30 for the spindle.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
All the wire. 2 runs of 4ga ofc stinger, ofc 4 ga Rockford for the big 3, some 150 amp fuses,cadence audio rca and remote wire.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
I have been working on this build for a few weeks now, so I am about done with it so I will be posting a lot of pics, I lost alot because my phone got fucked up. I should also say thanks to dubndodge for helping me out with questions I had. And inspiring me with his build to Give a sealed off trunk a try.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Big 3 in 4ga Rockford fosgate with a 150 amp fuse. I don't plan to upgrade alt at this time that's why I went with 4ga, and I had it just sitting around. Alt is a 105amp.also just a pic of the 2 runs going to back. Batt is a parts master super start platinum. Witch I was told was a DEKA.
IMG_20140415_092129_232_zps13h22mkt.jpgIMG_20140415_092211_5912_zps4ks5xqva.jpg[/urlIMG_20140415_125908_523_zpsax4oiw6h.jpg
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Just got this bad boy :) hc2400 resting at 13vIMG_20140415_141806_130_zpsjo9riw9b.jpg
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
OK so subs and amp box are coming out from my last build in my 2013 sportage.
Because I don't want the setup in it now due to using it more as a family car. So on with it...
Box 4cuft tuned to 40hz 84" port area
21" port per foot
DF48F183-2B53-498D-BD1B-D7CB6AE3ADC3_zps53572A49-BDB7-4716-8673-B39545D464AA_zps
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Subs soundqubed hdc3 12s 28D5AD15-644C-4E5D-834F-1011902917F9_zps0FF7D436-EA2C-45A8-9EF2-8A1DE0C2755B_zps
B5D26A23-22B7-4B85-BBCB-479EAAAB1476_zps
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
nice start!!!
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
nice start!!!
Thanks
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
