Got metered for the first time today. Input?
Not saying its not possible but no reason to get his hopes up. Takes the right box with the right subs facing the rght way.
I think its possible to jump from a 136.6 to a 140 with a box correctly built and designed for those subs. But to go from that 140 to 145 from double the power is not likely. I could see a 141-142 on 1200rms with a good box and a pair of 12s. Could see 145 from 2-3krms with subs that can take the power in n the right box and electrical to support it.
I've done low to mid 140s (142-143) with a single 15 and 2 12s on a 1500.1 bdcp. 12s should have been better but cause of flaws in the box design. Didn't have much for electrical at the time either. Was seeing 11.9-12.2v at the lowest during burps. Occasional 11.9-12.2 on music with certain songs for a split second. Voltage taking at the amp but usually stayed above 12.2 on music.
so is it possible yes is it worth to get your hopes up no.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Thanks for all the input guys. Hopefully I can decide on an amp under 2k watts to stay in the class I want to compete in.
The other thing is I need to go back and pay for some time to use the TermLab and test my box facing rear as well as different rear seat positions. I know it sounds a good bit louder with my box facing into the trunk instead of toward the cabin, but I use my car for work and always have to throw tools in it so its facing cabin right now.
07 KIA Spectra
320a Singer Alt
Odyssey Extreme batteries
2 12" Phantom sounds (4.6 cu. net @ 32) - soon to be 2 Atomic ELE
2 Rockford Fosgate T2500bd-CP
Zapco Z150.2
Front comps soon to be Hertz HSK
Pioneer 80prs
Second skin deadener throughout
Most of the time rear facing will be louder but yea it's all in testing
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Never been all that into SPL, but had a classmate back in high school that got into it. His first setup was four 10" 500RMS Eclipse subs in a fairly large sealed enclosure, probably 1.5cuft per sub, getting rated power. Heard he hit 143 something at COMP with it, so 136.9 off two 12's getting 600RMS doesn't sound too shabby. I could see them hitting 140dB properly powered.
Pretty much have to double your power to get roughly 3dB in gained output, so to go from 137 to 145, you'd be needing to bump up the power to a good 2500RMS, which those subs aren't likely to take. Well, maybe doing SPL burps.
Change out the enclosure for a larger one tuned a couple Hz below the vehicles resonance frequency and you'll get the most from the setup, but it'd be strictly for SPL, as the tuning would be quite high, like in the mid 50's or higher, depending on the car.
I've not ever been all that into LOUD myself, loudest setup "I" had was a 15" Kicker in a 34Hz tuned 3.5CUFT enclosure. Probably was capable of hitting in the 130's as well, but grew tired of it QUICK. Sounded like crap with most everything I listened to, with the only exception being Rap/Hip Hop.
Yeah I would make a couple ports that would be swappable so I could SPL and daily drive. I have never been into SPL either. This is my daily set up for music. Sounds good on all types, because I listen to all types of music. I wont be doing burps with any more than I give the subs daily at this point. But who knows, if I get the itch I might :)
07 KIA Spectra
320a Singer Alt
Zapco Z150.2
Pioneer 80prs
Yeah, swappable ports sounds like a pretty decent idea, if you can implement it properly
IDK, maybe I've just not ever had the right sub and/or ported enclosure, but I've never had a ported setup "I" felt worked well with all of my music. Never really had a chance to sample other peoples setups with "my" choice in music, so I can't comment on weather or not such a setup exists. Still, it's all about preferences, not to mention all the variables such as enclosure size, tuning, placement, Sub's T/S Parameters, source signal quality, final impedance, quality of the gear used, not to mention how everyone's hearing differs.
I'm looking to get back into a ported setup, at least to give it another shot. Currently running Polk MM1240's in 1cuft GROSS enclosures, sound pretty decent, but just not quite right with my Rap/Hip Hop, which is but 25% of my music at best. Thinking of doing a dual enclosure setup, in which I have a sealed and ported sub setup powered off separate amps, which I can switch between depending on my music and mood.
You cab get up to a 3db gain from each of the following double power, double cone area, electrical, and box. At the end of the day I wouldn't expect more then a a 1db gain from Each of those.
right now your biggest gain from those subs will be the box though. That's just because going from .69cuft per sub to the 1.25-2cuft per they should have along with a proper port. Proper bracing will help to.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
True, in a perfect world, 3dB gain is the rule of thumb, but we're dealing with other factors, such as loss due to cancellation between drivers and loss due to panel resonance.
Speaking of which, once can get a slight bump if they can deaden their ride properly. However, I've seen some of what goes on with doing such. add a little deadening, measure output, add some more, measure again, get a lower reading, remove what you just added. Quite monotonous, but if you're looking to squeeze out every .1dB you can, it can help.
But yeah, biggest gain is likely going to occur with a different enclosure. More power and placement of sub/port direction are likely next. I've heard of lots of little tricks and numerous factors, all I can say, it's not for me. Too much work for way more output than I'm needing, or even wanting. I'm fine with a daily driver that hit's upwards or 120dB. If I were into SPL drags, then I'm sure I'd be singing a different tune.
So why am I in the SPL section? Good question.
  • 3 weeks later...
post some pics ..and maybe I could show you more options :)
2018 Db Drag Street Trunk World Champion 156.9
2017 NSPL Trunk World Champion World 158.8
2016 Db Drag Street Trunk World Champion 156.7
2015 Db Drag Street Trunk World Champion 155.7
2015 NSPL Trunk World Champion World 158.3
2014 IASCA IDBL Trunk/Pickup 3 World Champion 157.1
2014 NSPL Trunk World record holder World Champion 157.4
2014 DB Drag Street Trunk World Record holder 154.4
2013 NSPL Trunk 0-48 World record holder 153.8
2013 IASCA Advanced Trunk 1 World Champion 155.5
2013 IASCA Advanced Trunk 2 World record holder 155.4
2013 DB Dragracing Street Trunk World record holder 154.3
2013 DB Dragracing Street Trunk Spring Break Nationals Champion
2013 Spring Break Nationals Champion IASCA Advanced Trunk 1
2012 NSPL Trunk 0-1800w World Champion record holder 151.3 @ 1731w 2012 IASCA Trunk 2 World Champion record holder 156.1 2012 USAC Trunk 1000 + World Finalist 158.4 2012 DB Drag racing Street Trunk World Champion record holder 154.3 2012 NSPL Trunk 3600+ World Record 156.7 legal/sealed/dash 2011 USAC Trunk 1000+ World Record 159,4 2011 NSPL Trunk 3600+ World Champion 2011 NSPL Trunk World record 156.6 dash 159.6 kick 2009 25-48NW NSPL World Champion 2009 Db Drag US.Top Certified SPL .St C 158.7 2008 Db Drag US.Top Certified SPL .St C 158.4 2008 25-48NW NSPL World Champion 2007 U.S.Top Cert. Street A,B,and C 2007 NSPL 0-24NW World Champion 2006 Db Drag St A World finalist. 2006 NSPL 0-24NW World Champion 2005 Db Drag St A World Champion 2005 NSPL 0-24NW World Champion 2004 Db Drag St A World finalist 2004 Db Drag US.record 642 points 2003 Db Drag Points World Champion 2003 NSPL 30-60NW World Champion 2002 Db Drag SS1-2NW World finalist 2002 NSPL 30-60NW World Champion 2001 Db Drag St 1-2 World finalist http://www.facebook....erry.SPL.Brocks Back in 02 my girlfriend said I had to make a choice between her and my love for car audio ......I told that b-tch I've made harder decisions at the Coke machine.
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
