Overheating Amp
Jesse Dresselhaus
I run a Kenwood amp that runs very hot at 2-ohm nomial resistance.
A way I helped it was just going bonkers on the wire I am using.
For a mere ~500W I am running 4 gauge OFC with doubled up 14 gauge speaker wire. I still get hot, but it fixed a lot with that design.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
So does this mean that I can run it below the rated resistance if I double up the speaker wire?
No. I was just stating my Ohm load for those that cared.
My amplifier "states" that it is 1-Ohm stable, but was hot and unstable on normal wiring at 2-Ohms.
where is your amp grounded to? what gauge wiring are you using for power and ground? how did you attach the wire lugs to the wire?
I wouldn't jump to any conclusions till after you get a multi-meter and see what you are running at.
My experience was with a whole completely different brand, however, still in the cheaper design category.
Your problem could just be as simple as accidentally wiring below suggested resistance. If not then you may have just got an amp that runs hot, and as long as it doesn't start spewing smoke or you hear a pop, I would call it good.
DMM's you can get at wally world or home depot. You can also get some amp fans for cheap on eBay or make your own out of some small fans that they put in cooling tables if you dont want to buy any and are on a budget.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
  • Who's Online   0 Members, 0 Anonymous, 686 Guests (See full list)
