kinetik hc2400
Friend has a hc2400 that he wants 120$ for, and I am thinking I want it. What should I look for to make sure its OK.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Bump
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Ideally:
Resting voltage check - checks for sulfation of plates and any bad cells
Short term high draw load test - checks for internal resistance
Long term low draw test - checks the amount of electrolyte still in the battery. Measure time and amperage draw to get a rough idea
What should it rest at? I will be picking it up tomorrow
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Preferably 12.8-13V if it doesn't, charge it and see where it goes
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
I don't have a charger yet. Plan is to use it up front. Think if its under 12.8 I will just walk away
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
I would probably still take it if it was 12.7 but any lower I would walk
06 monte carlo
2 12 rockford p3s
ct sounds 125.4
So what do you guys think is to low?
I think kinetik site said it should rest at 12.9-13.1
But I don't know how long its been sitting...
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 3876 Guests (See full list)
