Amp cutting off
AASMDBASS
When you say "bass knob" are you talking about the remote gain control that came with the amp? if it is an actual bass boost, turn it and leave it down. If your gains are set properly, you almost never have room for boosting any frequencies.
A DMM can't detect clipping so it is a bad tool to use to set gains with.
Are you running dual inputs on the amp?
There are 4 things that will put that amp into protect: Speaker shorts, DC offset, High/Low voltage, Thermal protection
Sorry yes just the knob WITH the amp, and my AQ 3500 does not have the dual inputs... Older model... Just can't seem to grasp what the culprit here is
Pioneer DEH 80PRS HU
Ascendant Audio SMD 18"
Audioque 3500.1D
XS Power D3100
Rockford T1 components
Rockford P400X4
Then I'd go around the car with a wrench and verify all connections are tight. That includes any terminals on your box and the terminals+tinsels for your sub. Pull out your head unit, make sure the RCAs in there are tight as well.
If your bass knob accepts RCAs, check those are tight, Also wiggle them around to see if there is a loose connection inside the wire
If it's the kind that plug into the amp: Unplug it and see if the problem persists
You're gonna hate me for this... Hahaha But... If it persists after I unplug the knob, then what? Pour some gas and light a match? Haha just trying to get to the bottom of this and I know there are very knowledgeable people on here
Audioque 3500.1D
XS Power D3100
Rockford P400X4
How can you verify that the amp is shutting off completely vs. it just not producing any output?
Check voltage at the amp while playing one of said songs starting at a low volume and gradually turn it up until it shuts off. What do you get? This needs to be done to make any progress/find a solution.
Well I mean you could do that.... LMFAO
Check all the other stuff I listed ;)
I'll ask this: How is your amp mounted? Does it vibrate? Check the mounting tabs where they attach to the amp. I've seen it happen where they got slightly loose and broke the RCA off the board.
Bass adjudted with a dmm does not equal correctly as you claim.
It was set at a car audio shop... I didn't do the install but they told me everything was set correctly and no clipping issues
If all they used was a dmm, they can not accurately tell you that.
What is your maximum undistorted HU volume? WHat is the max volume you use while listening?
Let me put it this way: The more simple stuff that either checks OK, the more complicated it's going to get.
I wish I knew... What piece of equipment can I use to determine that? I have the pioneer DEH 80PRS... Also I'm not 100% sure that all they used was a DMM... I can find out
Audioque 3500.1D
XS Power D3100
Rockford P400X4
Just talked to them and they said a DMM was used
Audioque 3500.1D
XS Power D3100
Rockford P400X4
Any way it could point to the amp being bad/going bad? I bought it used 2 years ago used and had to have the RCA repaired about a year ago...
Audioque 3500.1D
XS Power D3100
Rockford P400X4
The DD-1 is the easiest/best to use for tuning an amp/HU.
Your HU is probably clean all the way to full tilt.
  • Who's Online   0 Members, 0 Anonymous, 615 Guests (See full list)
