AASMDBASS Posted April 8, 2014 Report Posted April 8, 2014 I have an AQ 3500.1 and 1 18 smd... Have had them for 2 years and every once in a while if I play a song that has frequencies around 27hz, and the bass knob half up, the amp will shut off completely... The gain on the amp is right around half, and has been correctly adjusted with a DMM... My question is what would cause this to keep happening... It happened 3 times today and it's driving me insane... Electrically I have the stock battery under the hood, an XS Power D3100 secondary battery, big 3,and a DC power 270 amp alt, custom box at around 6cu ft tuned to 32hz... Please help, thanks Also, iI don't know what noise a sub makes when it bottoms out, but to me, it sounds like that happens right before the amp shuts off... Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4
n8ball2013 Posted April 8, 2014 Report Posted April 8, 2014 Bass adjudted with a dmm does not equal correctly as you claim. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
SnowDrifter Posted April 8, 2014 Report Posted April 8, 2014 Voltage at your amp when this happens? Verified all connections and RCAs are tight? What happens if you unplug your bass knob? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
AASMDBASS Posted April 8, 2014 Author Report Posted April 8, 2014 Voltage at your amp when this happens? Verified all connections and RCAs are tight? What happens if you unplug your bass knob? Haven't checked it yet... But let's say the voltage is about 13...then what would you assume? Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4
AASMDBASS Posted April 8, 2014 Author Report Posted April 8, 2014 And the RCA are tight Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4
AASMDBASS Posted April 8, 2014 Author Report Posted April 8, 2014 Bass adjudted with a dmm does not equal correctly as you claim. It was set at a car audio shop... I didn't do the install but they told me everything was set correctly and no clipping issues Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4
SnowDrifter Posted April 8, 2014 Report Posted April 8, 2014 Voltage at your amp when this happens? Verified all connections and RCAs are tight? What happens if you unplug your bass knob? Haven't checked it yet... But let's say the voltage is about 13...then what would you assume? You know what they say about assumptions ASSUME Makes an ASS out of U and ME ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
AASMDBASS Posted April 8, 2014 Author Report Posted April 8, 2014 Voltage at your amp when this happens? Verified all connections and RCAs are tight? What happens if you unplug your bass knob?Haven't checked it yet... But let's say the voltage is about 13...then what would you assume? You know what they say about assumptionsASSUME Makes an ASS out of U and ME Lol...I'm just looking for hypotheticals... If everything checked out voltage wise... Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4
SnowDrifter Posted April 8, 2014 Report Posted April 8, 2014 Then I'd go around the car with a wrench and verify all connections are tight. That includes any terminals on your box and the terminals+tinsels for your sub. Pull out your head unit, make sure the RCAs in there are tight as well. If your bass knob accepts RCAs, check those are tight, Also wiggle them around to see if there is a loose connection inside the wire If it's the kind that plug into the amp: Unplug it and see if the problem persists ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
rockFord_Expedition Posted April 8, 2014 Report Posted April 8, 2014 When you say "bass knob" are you talking about the remote gain control that came with the amp? if it is an actual bass boost, turn it and leave it down. If your gains are set properly, you almost never have room for boosting any frequencies. A DMM can't detect clipping so it is a bad tool to use to set gains with. Are you running dual inputs on the amp? There are 4 things that will put that amp into protect: Speaker shorts, DC offset, High/Low voltage, Thermal protection Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
